callum1980
May 25, 2023Aspirant
Nighthawk X4S R7800 showing wrong country or location
I have a nighthawk X4S R7800 used as an access point, connected to my ISPs (sky broadband) router. The Sky router when I am connected to it directly works well (but it doesnt have good range, hence ...
callum1980
michaelkenward answers below in red and underlined.
Does that mean that it is set up as an access point in the browser graphical user interface (GUI)? - yes, I set up the access point rather than router or bridge.
As @plemans says, do that and the router Sky Box sets the IP address for the R7800. - thats what I have done
So I turned off the sky routers wifi hoping that the nighthawks range would be better, and it is.
If you do that, the Sky Box still works as a router. So you should put the R7800 into AP mode. (See above.) - yep, i know how to set up the AP as I have already done that.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
However when connected to the nighthawk wifi (it uses the same SSID as Sky) when I surf the internet or use apps on either my phone / desktop it thinks im in another country.
What tells you that? - i use the same name and password for the nighthawk as I wouldve used for the sky router.
How can the R7800 use the same SSID as the Sky with its wifi turned off? - it only uses the name, not the actual service and when you set up the AP it recommends that you switch off the ISP wifi.
What do you see in the settings here:
- Basic
- Wireless
- Region Selection - EUROPE
- although both ENABLE SMART CONNECT and ENABLE SSID BROADCAST is not ticked.
michaelkenward
May 25, 2023Guru - Experienced User
Disable SSID broadcast and your R7800 will be invisible on the network.
In my screenshot, only the 2.4GHz is visible.
If you enable Smart Connect that will be unticked.
