ruudvdlaar
Sep 25, 2019Aspirant
Nighthawk X4S R7800 wireless no longer working
The WiFi on my router stopped working after my 2 week holiday (it was off during this time). The home screen of the router admin GUI shows 'Wireless Warning OFF'. And also the lights on the devic...
- Sep 30, 2019
I suggest contacting support if the router is still under warranty could be a hardware failure.
https://www.netgear.com/support/contact.aspx
DarrenM
DarrenM
Sep 27, 2019Sr. NETGEAR Moderator
Have you tried to factory reset the router by holding the reset button for 10+ seconds? Then you have to set up the router again.
DarrenM
- ruudvdlaarSep 28, 2019Aspirant
Yes, I have tried that numerous times. Also updating and downgrading to several newer and older versions of the firmware including 1.0.2.52, 1.0.2.58, 1.0.2.60, 1.0.2.62. And also resetting after these firmware updates/downgrades. Nothing works.
- DarrenMSep 30, 2019Sr. NETGEAR Moderator
DarrenM
- ruudvdlaarOct 04, 2019Aspirant
Thanks. I did and am having it replaced by a new one while it was still under warranty. The wireless module seemed to be broken and could not be fixed.
