aoz
Feb 21, 2018Tutor
nighthawk X4S, ReadyShare, FTP, cannot connect
trying to set up REadyShare, for FTP access, from remote internet. address Is (simulated) ftp://172.50.203.60/shares I hvae configured ReadyShare to allow the FTP, remotely, at this address, a...
- Feb 28, 2018
actually, I FIXED this ! (in past couple days). I tried another USB stick, clean, blank, and it actually WORKED !! SO, I took the SCREWY one, reformatted it, cleanied it off, added new data, pluged it in, and IT worked !!
SOMETHING must have been wrong in its format, etc, because now the FTP works, and another issue, the BROWSE for folders, works !
thanks to everyone for their replies!
schumaku
Feb 28, 2018Guru - Experienced User
What JamesGL does want to know if you are trying to reach the services using the WAN/Internet IP address from within the same LAN - instead of using the router LAN IP address. The WAN IP can't be used, as there is no NAT loopback possible. Why don't we have a control for this, JamesGL?
aoz
Feb 28, 2018Tutor
