DWWood's avatar
DWWood
Nighthawk X4S VoIP issues
Hi,
I bought the X4S AC2600 in the hope of better WiFi over my Foxtel branded Netgear modem. The older modem had 2 inputs for VoIP phones but I can't seem to get my VoIP phone working with the Nighthawk. Any help would be greatly appreciated.
    • DWWood's avatar
      DWWood
      Thx for the quick reply microchip8
      Being a absolute amateur with this stuff, is there something I can plug into the phone wall socket to get the VoIP phone working while also running the DSL connection to my modem?
      • antinode's avatar
        antinode
        Guru
           Actual model numbers for both devices might have been interesting.
        > Model: R7800|Nighthawk X4S AC2600 WiFi Router
           Is that accurate?  Firmware version?
        > [...] The older modem [...]
           Judging by the picture, it's a modem+router.
           If your goal is better wireless-network coverage, then you might
        leave your "my Foxtel branded Netgear modem[+router]" where it was, and
        configure the R7800 as a wireless access point.
           Visit http://netgear.com/support , put in your (actual) model number,
        and look for Documentation.  Get the User Manual.  Look for "Use the
        Router as a WiFi Access Point".
