whiltonm's avatar
whiltonm
Nighthawk X4S won't find modem
My internet went down altogether, and my local internet provider had to send a tech to the house.  He said that somehow our modem had been taken off our account.  He reassigned it, and we got the mod...
  • Blanca_O's avatar
    Jun 17, 2018
    Hi whiltonm,
    Welcome to NETGEAR Community!
    Just to clarify, do you have Internet access when wired to the router? If so, then we will focus on the WiFi connection. You mentioned that "the wireless won't show up", are 2.4GHz and 5GHz LED lit? If not, please press the WiFi button (2nd button from the right) for 2 seconds to turn on and off the WiFi function of the router. Other option to turn on WiFi radio of the router is to access its user interface. Kindly click this link as your reference.
    Blanca
    Community Team
