NGbaby
May 03, 2018Tutor
Nighthawk X6 - Model R8000 INTERNET repetitive disconnects with no log
Hi my router worked well after the last firmware update some months ago. Firmware V1.0.4.12_10.1.46 . Then about 10 days ago it has started disconnecting very frequently and repetitively, and reconne...
- May 27, 2018
Hi, thanks James. I did install it earlier today.
I imagine that it must be related to the security issues in the news.
supposed to allow auto update of the firmware too.
Hopefully all goes well and keeps hackers at bay.....
But also this morning I had the visit of my 3rd technician and I am hopeful it is going to be finally working well.
First technician did some connections tightening and changes and changed my modem to another thomson. Not better five minutes after he left
I went to mediacom shop the next day to get another modem, arris, better.
2 days later second technician was helpful finding out and telling me there was a capacity problem sometimes (that appears in logs at the provider) and that he was going to ask to be looked at.
Then nothing happened during 2 weeks and still internet often bad.
No news about capacity increase when I was asking and it did look like problem was still too present to be only that.
Called and complained last week and Surprise: Third technician rings at the door this morning today.
I think he did a good job, very methodical, replaced some cables that were dammaged from ?rabbits, checked every connection and splitter. changed several. Noticed also I was using a ethernet cable from modem to wifi that was maybe a limiting factor in the speeds and not related to the drop we think
Very happy with him. Very hopeful. No issue for the last 12 hours and I saw the firmware and updated.
So modems might be more or less performant with a bad signal but I think 2 main factors to my problems have been
-coax dammaged and connections loose or deficient (hopefully all fixed for the moment)
-maybe capaicity
To have an increased capacity provider must do increase of capacity and it might not happen soon but I will be challenging them if problem
Also I have a 8 channel modem, might go and buy a 16 channel one. Hearing it could help.
If I think about the technicians I have had,I have seen others and none was as professional as the one today I think and I had given up on a TV problem (frozen frames) on TV for the last 2 years, getting worse last 2 moths while internet also underwent issues leading to this post.
Will check whether it improved or still happens.
Pretty thankful to the technician of this morning also I have learned a lot thanks to talking to them and this chat. Thankful to this chat too.
NGbaby
May 06, 2018Tutor
Went down again.
still looking at the model signal for clues
but on top of that there were DDOs attacks that totally ruined us during 10 minutes
but this time It went down terribly 3 times in 6 minutes (and ruined my son's game on xbox)
and at the ery same time there were DDoS attacks
The modem log is full again and I can't copy paste
but there were 3 MTA resets at 11:51 11:53 and 11:55
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 12:00:50
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.35.204.141], Sunday, May 06,2018 11:56:40
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.35.207.10], Sunday, May 06,2018 11:56:37
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.35.204.15], Sunday, May 06,2018 11:56:37
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.35.204.141], Sunday, May 06,2018 11:56:37
[DoS attack: ACK Scan] attack packets in last 20 sec from ip [23.35.204.141], Sunday, May 06,2018 11:56:34
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.10.240.216], Sunday, May 06,2018 11:56:33
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:55:52
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:55:27
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:53:58
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:53:33
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [35.186.224.62], Sunday, May 06,2018 11:52:11
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:51:49
[UPnP set event: Public_UPNP_C3] from source 192.168.1.60, Sunday, May 06,2018 11:49:48
Basic Status Basic LAN |
IrvSp
May 06, 2018Master
If you note between the two postings of the UPSTREAM parameter's that the second does NOT have #2, and the modem is probably trying to correct that by rebooting or initializing. Could very well be the cause.
Here is a link on power and SNR (Signal to Noise Ratio) that might be of interest, http://www.motorolacable.com/documents/CableConnection.pdf.
Another thing on the modem is to look at the CORRECTEDS and UNCORRECTABLES and that CAN be large numbers. I've attached my modem's screenshot of those. No matter how many you have, they should not large compared to the Octets, a miniscule amount.
Too many DoS Attacks though can shutdown the router for 20 seconds if from the same IP Address I think? Might want to Google "how to stop ddos attacks on netgear router" to see more on this. However, you will find Googling any DoS Attack that a majority will be Netgear routers. I suspect the routers are giving FALSE POSITIVES. I get them quite often, and many different forms. When I check the IP Addresses they are usually some site I go to, like Amazon, or Akmai (sp?) which most sites use for Advertising/cookies. I attribute it to the router dropping a bit here or there or was in a busy state to handle it. Could be the modem 'thought' it corrected a TCP/IP packet and sent it to the router and router thought it was bad? I just don't know, but I ignore those.
