miztrniceguy
Nov 25, 2015Aspirant
Nighthawk X6 : cannot connect to 2.4G printer when laptop on 5G
I just got a Nighthawk X6. It's got great coverage, but when my laptops are connected via 5G then I cannot print anything. My printer (like all others it seems) can only connect via 2.4g. Wired to ro...
- Nov 30, 2015
The wireless clients behind the RT-56U cannot see the wireless clients behind the X6 and vice versa. Moreover, the Wired PCs cannot see any wireless clients. Even with wireless disabled, the cable modem is still operating as a router.
My recommendation still stands: convert the X6 and RT-56U to APs. BTW, you could have used cheaper range extenders as APs.
joedrt
Nov 29, 2015Aspirant
Since you cannot move the printer, you may have to consider purchasing a wireless print server that connects to the router.
