miztrniceguy
Nov 25, 2015Aspirant
Nighthawk X6 : cannot connect to 2.4G printer when laptop on 5G
I just got a Nighthawk X6. It's got great coverage, but when my laptops are connected via 5G then I cannot print anything. My printer (like all others it seems) can only connect via 2.4g. Wired to ro...
- Nov 30, 2015
The wireless clients behind the RT-56U cannot see the wireless clients behind the X6 and vice versa. Moreover, the Wired PCs cannot see any wireless clients. Even with wireless disabled, the cable modem is still operating as a router.
My recommendation still stands: convert the X6 and RT-56U to APs. BTW, you could have used cheaper range extenders as APs.
miztrniceguy
Nov 29, 2015Aspirant
Not sure what was wrong, but now I can see the printer and print from both laptops as long as they connect to that router and not my upstairs router. Eventually I plan to move my Nighthawk X6 to a more central location and I hope it will provide better coverage upstairs. But I need to wun a Cat5 cable to the location above the staierwll I plan to locate it. Surprisingly though, I can only see mt WD MyCloud when connected by ethernet cable.When I connect it to X6 via USB it doesn't see it. I will have to look at that later.
Thanks for the suggestions.
TheEther
Nov 29, 2015Guru
Ahh, so you have two routers. You should understand that devices on the WAN side of the router cannot see devices on the LAN side of that same router because of the firewall. This can be addressed by reconfiguring the router to run as an Access Point (AP), so long as it's connected to the main router via Ethernet.
- miztrniceguyNov 29, 2015Aspirant
The second router (Asus RT-56U) is not connected to the first. i connects via a Powerline Adapter to a different port on the cable modem. I use it to provide better coverage upstairs. The current location downstairs in a far corner does not adequately provide coverage to my bedroom in the upstairs opposite corner. My wife sometimes works there and the connection often drops. I hope to have a wired connection added in a central location soon so I cane use just the X6. I have the wall ports and cable, just need to have it installed.
- TheEtherNov 29, 2015Guru
Now, it sounds like you have 3 routers. Let me see if I got this right:
Cable modem/router-----Ethernet-----X6-----Wired PCs
Powerline Wireless clients
RT-56U-----Wired PCs
Wireless clients
With this setup the clients behind the X6 can't see the clients behind the RT-56U and vice versa. You should configure both the RT-56U and the X6 as Access Points. Your cable modem will function as the main router.
An alternative setup is to put the cable modem into bridge mode. This will disable its router function. Then use either the X6 or the RT-56U as your "main" router. I find this to be safer because this place all your devices behind your own router and out of the hands of your ISP. The following example shows the X6 as the main router:
Wired PCs Wired PCs
Cable modem-----X6-----Ethernet or Powerline-----RT-56U as AP
Wireless clients Wireless Clients
Cable modem has wireless disabled. This is what it looks like
Cable modem/router-----Ethernet-----X6-----Wireless Clients downstairs
| Wired PCs
Powerline
RT-56U-----(Wired PCs-none)
Wireless clients upstairs (too far from X6)
