Sodaman005
Sep 30, 2022Aspirant
Nighthawk X6 3200 router - cannot connect
I have an Internet connection that I have checked going into the router, my Wi-Fi shows that it is available, but when I connect, it says there is no Wi-Fi connection
Sodaman005
And amber internet light is flashing
Sep 30, 2022Guru - Experienced User
Is this the R8000?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
