Tangoqueen
Sep 18, 2021Initiate
Nighthawk x6 ac2200 connecting issues to Nowtv hub 2
just received and problems setting up. I'm using the nighthawk app but it won't verify my routers password. My router is Nowtv hub 2. Any suggestions. Thank you
- Sep 18, 2021
have you tried installing using the installation assistant and not the app?
Sep 18, 2021Guru - Experienced User
- TangoqueenSep 18, 2021Initiate
Thank you so much, I think that's worked
- plemansSep 18, 2021Guru - Experienced User
Glad it helped!
Let us know if you have futher issues
