Jacklufc
Nov 13, 2020Aspirant
Nighthawk x6 ac2200 connection issue
I have setup an x6 tri-band WiFi mesh extender and it seems to be working on my mobile device. However, my wife’s mobile is now only connecting intermittently, and when she ‘forgets the network’ and t...
Jacklufc
Nov 15, 2020Aspirant
Hi, I used the installation wizard.
Firmware is V1.0.0.210
I’m using a BT SmartHub 2
Nov 15, 2020Guru - Experienced User
try reinstalling version 1.0.0.206 of the firmware. factory reset the extender and do a clean install on it. disable its autoupdate for now. It seems like some are having issues with the .210 version.
- JacklufcNov 15, 2020AspirantThank you. How can I revert to the old firmware? Thanks for your help.
- plemansNov 15, 2020Guru - Experienced User
You download from the support site. Then extract it.
then just follow the "manual firmware update" process from the manual and instead of using new firmware, use the one you downloaded.
