StagByTriumph
May 31, 2022Aspirant
Nighthawk X6 AC3000 R7900 latency to ISP
Since the FW update to the version seen below, I have had a significant delay through my r7900 on both wired and WIFI. Email - both Outlook and gmail do not sync on first/second/third attempt - tak...
- May 31, 2022
Okay, I downloaded the previous version of the FW flashed the FW back to
Firmware Version V1.0.4.38_10.0.50
GUI Language Version V1.0.4.38_2.1.44.1The latency is GONE! AND the pages now refresh literally in a FLASH of the eye as they should.
That CONFIRMS the issue is with the latest FW. I will try to flash again to the latest by downloading directly from the NG site as the Router update should have, and see if the Latency returns.
I am not real comfortable going downlevel in FW due to the fixes are security bugs.
So how do I protect from the security flaws that have been patched / updated in the latest FW update?
So downgrading to the last FW is really NOT a "solution" because it negates security patches updates of the new version
May 31, 2022Guru - Experienced User
Did you factory reset the router after last FW version was updated and applied and setup from scratch?
Check NGs download page:
- StagByTriumphMay 31, 2022Aspirant
Thank you for the response, and I appreciate your question eventhough I know I wrote a lot of information where I did say I have repeatedly REBOOTED and factory reset, and that I do not need scripted answers.
So the short answer is YES, of course I rebooted after the FW update, which BTW the Router does automatically after flashing the FW, and I rebooted after each change in configuration (also an automatic function in the Router) when I was trying to find the cause of the latency problem inside the router.
Since I have had this latency problem I have probably rebooted EASILY 20-30 times, factory reset at least 5-6 times, rebuilt my configs from scratch, and the latency exists no matter what I do.
- FURRYe38May 31, 2022Guru - Experienced User
Something to let NG know about then. You may contact them and let them know of your experiences:
