jgeorge116
May 27, 2023Aspirant
Nighthawk X6 AC3000 (R7900) Speed Not Reaching 500mbps
Hello I am located in Texas, USA. I have the NETGEAR Nighthawk X6 AC3000 (R7900). I recently updated my internet speed from 300mbps to 500mbps. When I tested my hardwired internet to my desktop...
jgeorge116
I want to try and avoid a reset for now. Is it really the only option when once upgrades speeds?
I checked my current setting below.
QoS is NOT enabled.
Access Control is NOT Enabled
Traffic Monitoring: I don't see a specific setting for this but all traffic is allowed at all times
Parental Controls is DISABLED
Kindly let me know if you have any other ideas...
May 27, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
If this fails, you'll need to factory reset and setup from scratch. Do not load a saved configuration from file.
