StagByTriumph
Apr 07, 2023Aspirant
Nighthawk X6 AC3000 Tri-Band WiFi Router Model R7900
So my AV's have been bugging me to update my Router FW. Win11, HW Version R7900, updated to FW Version V1.0.4.46_10.0.53 GUI Language Version V1.0.4.42_2.1.44.1 So I decided, heck mayb...
michaelkenward
Apr 08, 2023Guru - Experienced User
StagByTriumph wrote:
FWIW, the DDoS were caught and blocked by Snort on my Ubuntu PC monitoring my network .
Here is what the router log picked up: [DoS attack: FIN Scan] attack packets in last 20 sec from ip [34.117.223.223], Friday, Apr 07,2023 10:56:56
That is a Google IP address.
This is a useful tool for reducing blood pressure and baseless paranoia.
IPNetInfo: Retrieve IP Address Information from WHOIS servers
As to this:
I cannot send a note to Tech Support I need to subscribe for a support call and pay a fee, this unit is no longer supported, and that money would be better spent on a new updated router.
One recent user said they had success using the "chat" facility at the boot on the support pages.
StagByTriumph
Apr 14, 2023Aspirant
Sooooo, have you never used Metasploit to phake or spoof a URL or IPV4 address? That is literally childsplay for a hacker and step #1 for any deployed DDoS. I highly doubt the DoS is actually originating from Google.
Like you state in your reply, the log files are full of garbage. Why is there no "actionable intelligence" at the point of monitoring? There is IDS and then there is IPS. IDS is simply monitoring with no action, no alarmiing, no interaction with any other Intrusion Protection System or software, all of which the general user public has zero understanding or concepts and information communication systems must be designed with security capabilities, which that is ISO/IEC2700x combined with Consumer Data Protection laws in many countries.
I'll reach out to Tech Support but I'll bet they tell me all the standard scripts: Reset the router, power off the router, reset the gateway, disconect all attached devices release and reset all Netstat's, pay for Armor, reload the FW, replace the router.
- FURRYe38Apr 14, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Is outlook the only app not working to connect to send and get emails?
Does this happen on other devices?
