SWesley
Aug 13, 2022Aspirant
Nighthawk X6 AC3200 - One device places Facetime call, and all other devices lose WiFi
I have a Nighthawk X6 AC3200 - This problem started in the last month. One device places Facetime call, and all other devices lose WiFi connections until call ends. Has anybody else experienced thi...
Aug 13, 2022Guru - Experienced User
What model router do you have? AC3200 is a combined wifi rate speed. R8000?
How many devcies do you have online at one time?
How do you have basic and Advanced Wireless configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Smart Connect enabled?
Is Armor, Circle or Traffic Meter enabled?
SWesley
Aug 14, 2022Aspirant
R8000
Router Firmware V1.0.4.84
Arris Modem
Model TM1692A
Live in cul de sac - 3 neighbors all w/wifi
2.4GHz channel 11
5Ghz 1 channel 44
5GHz 2 channel 153 (choices 149, 153, 157, 161)
Spectrum High speed internet
Download speed typically >150 mbps
Upload typically 20 mbps
Typically have 2 TVs on
3 iPhones on
1 laptop on 24/7
Total devices:
3 smart Roku TVs
3 iPhones
1 windows laptop on wifi
1 windows PC direct network connection
Smart connect disabled
Thanks for the reply
Arris Modem
Model TM1692A
2.4GHz channel 11
5Ghz 1 channel 44
3 iPhones on
1 laptop on 24/7
Total devices:
3 smart Roku TVs
3 iPhones
- FURRYe38Aug 14, 2022Guru - Experienced User
Does same thing happen with Smart Connect enabled?
