gaschneck
Nov 10, 2023Aspirant
NightHawk x6 AC3200 Connected to Spectrum Router not working properly
I recently setup my NightHawk X6 AC3200 router behind the Spectrum router and it does not seem to be working properly. The cable is from a LAN port on the Spectrum to the WAN port on the NightHawk. ...
michaelkenward
Nov 10, 2023Guru - Experienced User
Which one?
AC3200 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
microchip8 has already pointed to the probable cause of your problems, but if you need more help check the appropriate section for your hardware
On the Nat thing, try this:
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
and check this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
