RCdammit
Jul 21, 2025Guide
Nighthawk X6 AC3200 model R8000 no lights
Howdy. For years I’ve had this router (Nighthawk X6 AC3200 model R8000 no lights ), and periodically it would stop allowing me to join the WiFi. My cure for this is to unplug it and plug it back in, ...
- Jul 22, 2025
Thanks everyone! The problem is resolved. Y’all got me to test output of the power adapter, and I got no power at all there… UNTIL I checked the plug which brings AC power into the “brick.” That plug was loose at the brick. I corrected that and now the router is back in action!
Thanks again!
Jul 21, 2025Guru - Experienced User
got an old matching power supply sitting around you could test with it? usually when all the lights are off, its either a power supply issue, the switch is off, or the jack broke.
RCdammit
Jul 22, 2025Guide
I’m not sure I do, but I can test the output of the power supply and if it’s good I can check the jack. I’ve had to re-solder jacks when they come loose.
