collinray8
Nov 10, 2020Aspirant
Nighthawk X6 AC3200 not connecting to Spectrum Modem
I bought this router secondhand from someone and it appeared to be brand new in the box. I have downloaded the Nighthawk App to get the router set up. I am having issues getting the router to connect...
Nov 10, 2020Guru - Experienced User
try this.
Factory reset the R8000. Push and hold reset for 7-15 seconds while its powered on. Maybe it was installed and an old setting is cause issues.
once its reset power off the modem and the router. disconnect everything from both. (even coax from modem)
connect coax back to the modem. power it on. wait several minutes for it to fully boot.
connect the lan cable from modem to wan port on router.
power the router on. give it several minutes to boot.
Then attempt setup on it.
- collinray8Nov 10, 2020Aspirant
I tried your recommendation, but did not have any luck getting past the same point of "no cable detected".
Is the "loop test" of plugging an ethernet cable into the WAN port and in a LAN port on the R8000 a valid test to determine if the internet port is bad?
- plemansNov 10, 2020Guru - Experienced User
you should be able to wan-lan test it.
does the arris work if you directly connect your laptop?
- collinray8Nov 11, 2020Aspirant
When I do the LAN/WAN test, the internet LED does not light up, but the LAN port in use does light up.
The Arris does work if I just bypass the router completely and plug in directly to my computer.
