kcordan1's avatar
kcordan1
Follower
Dec 29, 2020
Nighthawk X6 AC3200 R8000 router with sonos
I have my sonos set to my router.  How do I keep other people from getting on my sonos and changing music.
  • plemans's avatar
    the router doesn't control the sonos.
    You'd be better to ask this on the sonos website.
  • plemans's avatar
    If its ONLY  your network and people are getting on it, change the ssid/password of the router so others can't access it. Then they couldn't use the sonos. Otherwise, I'd check on the sonos support/forum.
