NetBillGeek
Jun 13, 2018Guide
Nighthawk X6 AC3200 R8000 Tri-Band no longer recognizes my Modem or Internet Connection.
My router ( Nighthawk X6 AC3200 R8000 ) no longer recognizes my modem or Internet Connection.
If I plug from the modem directly to the computer, the internet connection works fine.
If I plug...
- Jun 14, 2018
If I plug into the router for internet connection, the router doesn’t see the connection and won’t let me go online or connect to my Roku device, etc.
I did a reset to factory setting, but I cannot reconfigure the router after the reset because it still won’t recognize my internet connection.
Any ideas on how I can fix this?
Thanks!
Did the router 'ever' get the Internet connection or is this a NEW router?
I'm assuming the modem previously was connected direct to a PC and you got a router. If so, the modem needs to be power cycled. If is 'locked' onto the PC's MAC Address and rejects the router connection. So power down the router and all other devices. Power cycle off and on the modem and wait for it to come all the way up. Then power on the router, let it come all the way up and then power on the devices.
Still, as noted above, you do NOT need an Internet connection to configure the router. Just a connected PC via wired or wireless. Open a browser and go to 192.168.1.1 or ROUTERLOGIN.NET and you should start the router setup process.
IrvSp
Jun 14, 2018Master
Thanks!
NetBillGeek
Jun 14, 2018Guide
Thanks!
Hi IrvSp,
Thanks for the reply. Is not a new router. It was working fine for a few months and all of the sudden it stopped recognizing the modem or internet connection. I cannot use any of the devices connected to the router via wi-fi. Roku, AppleTV, iPads, etc.
I will try some of your suggestions and see if they take care of my problem.
- IrvSpJun 14, 2018Master
That is a 'different' story. Suspect a possible damage router or power supply.
What are the colors on the LED's?
With the PC that you could plug into the modem, can you use a browser and go to the router's homepage?
Do you have another cable you can use to connect the modem to router as the modem seems to be working? Possible the cable went bad between the two, however if you can't use a PC connected to the router to get to it, it could very well the router failed even? Best to try the RESET and see it that recovers it?
