H53
Aug 22, 2024Follower
Nighthawk X6 AC3200 R8000 Verify active TCP ports
I am getting connection errors and missed this step in the instructions:
If you are using a router, please set up your ports so that the below packets can pass through.
[Ports that may be used]
TCP:80, 443, 54992-54994, 55006-55007, 55021-55040
How do I verify these are passing through or set them to pass through if they are not?
1 Reply
Be sure uPnP is enabled or disabled if you configure Port Forwarding on the router.
Be sure your ISP modem or ONT doesn't have a built in router here. This effect port checking and usage.
