Bob_Raskey
Dec 07, 2021Aspirant
Nighthawk X6 AC3200 R8000
I'm miffed because I have a Netgear R6120 that has been great for years, but I have attempted to replace it for better range with the Nighthawk X6S AC4000 R8000P. However the Nighthawk does not recog...
- Dec 07, 2021
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Then log in to 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
I'd ask the ISP if there is any user account and password information needed to setup the router to work with there services. They should be able to help you set up any wifi router with there interface hardware.
Dec 07, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Bob_Raskey
Don't know the present firmware loaded.
Nighthawk X6s AC4000 R8000P, provider is PCI Broadband out of Colorado Springs, CO.
I'm told by the ISP that I have satilite service which provides an ethernet connection, shouldn't need a modem.
Plug it in with just the ISP connected and all I ghet is a flashing Orange Internet light.
Can't find a connection from it, I guess I won't if it doesn't connect/handshake to the ISP.
I try to access it via PC using 192.168.1.1, but then it asks me to answer security questions.
- FURRYe38Dec 07, 2021Guru - Experienced User
- Bob_RaskeyDec 08, 2021Aspirant
Furrye38,
That did it, had to go back to scratch to make it work.
The only item of interest is 15 seconds to reset didn't work,
then I remember someone else mentioned the reset button,
but they mentioned 45 seconds. That worked.
I followed the rest of your instructions ans was online in minutes.
Thank you for all your help, you are truly a lifesaver and master of the Net Gear.
Working like a charm now.
Bob Raskey
- michaelkenwardDec 09, 2021Guru - Experienced User
This is the well known "recovery reset" hand jive.
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
I mention it again because it can even be useful when someone has what seems to be a "bricked" device, one that will not complete the boot process and end up with a white power LED.
The recovery reset can eliminate the need to mess around with TFTP. It puts the device into a state where a standard manual update of the firmware will work.
