Bob_Raskey
Dec 07, 2021Aspirant
Nighthawk X6 AC3200 R8000
I'm miffed because I have a Netgear R6120 that has been great for years, but I have attempted to replace it for better range with the Nighthawk X6S AC4000 R8000P. However the Nighthawk does not recog...
- Dec 07, 2021
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 15 seconds then let go. Power OFF the ISP modem for 30 seconds than back on. Then log in to 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
I'd ask the ISP if there is any user account and password information needed to setup the router to work with there services. They should be able to help you set up any wifi router with there interface hardware.
Bob_Raskey
Dec 08, 2021Aspirant
Furrye38,
That did it, had to go back to scratch to make it work.
The only item of interest is 15 seconds to reset didn't work,
then I remember someone else mentioned the reset button,
but they mentioned 45 seconds. That worked.
I followed the rest of your instructions ans was online in minutes.
Thank you for all your help, you are truly a lifesaver and master of the Net Gear.
Working like a charm now.
Bob Raskey
Dec 09, 2021Guru - Experienced User
Ya normally a 10 second press is all that needed, however, seening some posts regarding needing longer presses or different press method processes recently. Glad the 45 second worked. I'll keep this in mine too.
Be sure to save off a new back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Bob_Raskey wrote:
Furrye38,
Bob Raskey
