ak_
Feb 01, 2024Aspirant
Nighthawk X6 AC3200 Smart WiFi Router (R8000) - issues -> No Ethernet Cable Is Plugged
Hi, I came across the issue few weeks ago and still was not able to fix it. All kind of support for this device already expired. Router was bought in 2020. I have modem SURFboard SB6141 Issue...
Feb 01, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
