ak_
Feb 01, 2024Aspirant
Nighthawk X6 AC3200 Smart WiFi Router (R8000) - issues -> No Ethernet Cable Is Plugged
Hi, I came across the issue few weeks ago and still was not able to fix it. All kind of support for this device already expired. Router was bought in 2020. I have modem SURFboard SB6141 Issue...
Feb 01, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
ak_
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended - it is the right cable (came with router)
yes, but less then 1 mins. And all was working fine.
Tried just now, no effect.
Any other idea?
Thanks
- FURRYe38Feb 02, 2024Guru - Experienced User
Factory reset the ISP modem.
Swap LAN cable between the modem and router. Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try a factory reset on the router and setup from scratch.
