LeeGillie
Jun 09, 2023Aspirant
Nighthawk X6 AC3200 Smart WiFi Router (R8000) DNS ISSUE
My router firmware version is: V1.0.4.84_10.1.84 I am having intermittent issues with DNS. I see this in a web browser. When I first go to a site it displays not available. but then a couple of s...
Jun 09, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? Happens in different browsers?
What happens if you enable IPv6 (Auto) on the router, save and apply, then reboot the router and power cycle the ISP modem/ONT and all connected devices. Be sure to clear all browser caches as well.
LeeGillie
I have xfinity/comcast as my ISP. I use my own xfinity approved modem:
The modem is: ARRIS Surfboard S33 DOCSIS 3.1 Multi-Gigabit Cable Modem | Approved for Comcast Xfinity, Cox, Spectrum & More | 1 & 2.5 Gbps Ports | 2.5 Gbps Max Internet Speeds | 4 OFDM Channel
https://www.amazon.com/gp/product/B08FMSC5WZ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Cable is CAT 6.
Doesn't matter which browser. I am a software developer, and I see it my own applications connecting to the outside. Sometimes after DNS resolution failure, I run my program again, and it works perfectly.
