LadyLuck719
Dec 23, 2020Aspirant
Nighthawk X6 AC3200 Throttling when I launch COD Cold War
When I launch COD Cold War my speeds are throttled. I have reset the router, added all the ports for port fowarding and updated firmware and still the same. I test my speed before launching the game ...
Dec 23, 2020Guru - Experienced User
What modem/gateway are you using?
Are you speedtesting while playing?
Whats playing the game and what's speedtesting?
LadyLuck719
Dec 28, 2020Aspirant
I have fiber. Default settings for gateway. Speedtest before starting game speeds ok speed test after they drop.
Call of duty is through blizzard. Speedtest.net is what I am using
- plemansDec 28, 2020Guru - Experienced User
LadyLuck719 wrote:I have fiber. Default settings for gateway.---what gateway? model?
What gateway?
Why are you speedtesting during game play?
What device are you speedtesting on? PC? Xbox?
What speeds do you pay for?
What speeds do you get hardwired into the router?
How if your console attached to the router? wired? wireless?
- LadyLuck719Dec 28, 2020Aspirant
What gateway? 192.168.1.1
Why are you speedtesting during game play? 520
What device are you speedtesting on? PC? Xbox? PC not playing game 930
What speeds do you pay for? 1 gig
What speeds do you get hardwired into the router? Hardwired 930
LadyLuck719 wrote:What gateway? 192.168.1.1
I'm not trying to be an a-hole but did you read these?
I asked what gateway you're using. that'd be a modem, fibre box, whatever the routers connected to. Not the ip address.
Then I asked why you're speedtesting during game play. You're not going to get max speeds because you're using it.
so you're testing on a pc. hopefull not the same pc you're gaming on. that'd be even more pointless as it takes processing power to game.
I then asked what speeds you got hardiwred into the router and you typed hardwired. you did answer this on a prior question that wasn't even about what speeds you go.
