Athl0nm4n
Feb 06, 2022Aspirant
Nighthawk X6 AC3200 WAN IP DHCP FAILURE
I have a dilema that I have debugged for too many hours. I have a Nighthawk X6 AC3200 that will not get an IP Address from my Internet Provider's cable Modem (Arris TM822). I have another router (...
Feb 06, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Athl0nm4n
Feb 09, 2022Aspirant
Thank you for your response.
- Yes I have tried powering off the cable modem and router for upwards of 30 minutes.
- I have attempted to factory reset both the cable modem and router.
- The NIGHTHAWK DOES NOT obtain a WAN DHCP IP address when connected to the ARRIS TM822 (CABLE MODEM).
- The TP-LINK (DD-WRT) DOES obtain a WAN DHCP IP address from the ARRIS TM822 (CABLE MODEM).
- My PC (ETHERNET) DOES obtain a WAN DHCP IP address from the ARRIS TM822 (CABLE MODEM).
- The NIGHTHAWK DOES obtain a WAN DHCP IP address when connected to the TP-LINK.
Internet Provider support did mention that they had issues with Netgear routers. Not sure if that means they have a permanent ban on them somehow but replacing the MAC on the WAN side should resolve that issue.
