ChrisMulr
Jul 14, 2019Aspirant
Nighthawk x6 Not Hard Resetting
I recently acquired a used Nighthawk x6 as a lot sale. I’m unable to contact the previous owners to ask for the password on the SSID. I figured I’d just be able to hard reset it an be good to go. How...
- Jul 14, 2019
> I recently acquired a used Nighthawk x6 as a lot sale. [...]
Perhaps you now know how it got there.
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Factory" or "reset"?Normally, the documented procedure (with no data cables connected)
will work. A Web search for terms like:netgear 30-30-30 reset
should find instructions for a supposedly more drastic/effective method.
When all the Reset possibilities fail, you might try the TFTP
recovery scheme. See, for example:https://community.netgear.com/t5/x/x/m-p/1622096#M102004
> [...] password on the SSID [...]
Use a wired connection, where the wireless-network passphrase makes
no nevermind?
antinode
Jul 14, 2019Guru
no nevermind?
- ChrisMulrJul 15, 2019Aspirant
The 30-30-30 method worked great for me. Thanks.
