wleebrown
Jan 31, 2022Aspirant
Nighthawk X6 R7850 Dropping Some Wireless Connections
I've been using the Nighthawk X6 R7850 AC3200 router for more than 1 year now. Until very recently, my network connections have been very stable., rarely required a reboot. I'm currently running the ...
wleebrown
I do not have IPv6 enabled. I did find the setting after some searching but there were a bunch of options. Any one in particular you would recommend? I'm going to try the first option, Auto-Detect, and see if that helps. Again I appreciate the help.
Thank you!
Jan 31, 2022Guru - Experienced User
Try auto detect
