Highspeedtek
Feb 22, 2021Aspirant
Nighthawk X6 R7900 Qos under 1Mbps
Anyone know what firmware I have to roll back to so I can set up Qos to under 1Mbps. I know I used to be able to do it with this router but now the lowest setting in 1Mbps. Thanks in advance.
Highspeedtek
Feb 23, 2021Aspirant
Does anyone know if I can even get older firmware versions? Thanks again
- DarrenMFeb 23, 2021Sr. NETGEAR Moderator
Yes here is the link to the older firmware
