odeca23
May 15, 2017Aspirant
Nighthawk X6 R7900 throttling internet speeds
I just recently purchased this router and it is not hitting my regular 1gbps speeds. I tried resetting the router, I have QOS off and traffic mngt off as well. When I plug my PC directly into my mo...
- May 26, 2017
Had to reset the router several times and then it finally caught the correct speeds.
thanks
ElaineM
May 26, 2017NETGEAR Employee Retired
