LuckyClover13
Nov 23, 2021Aspirant
Nighthawk X6 R800 interface with Orbi
I am looking to keep my R8000 nighthawk downstairs for gaming and add an Orbi upstairs to provide adequate coverage + speed instead of a Mesh, which I understand would cut down our overall speed. Does...
Nov 24, 2021Guru - Experienced User
If you're only needing 1 device, you could add a mesh extender. I'm a fan of the triband line as they preserve speeds more than the single/dual band extenders do.
LuckyClover13
Nov 24, 2021Aspirant
Thanks! I’m considering the Nighthawk Ext7500 or 8000 model. The Orbi sounds like a better option that could provide more stable coverage without dropout in speed, but it seems this would require revamping my setup. I can’t figure out if the two units are compatible.
- FURRYe38Nov 24, 2021Guru - Experienced User
R8000 is not compatible with Orbi. You can add a EX8000 to an Orbi system however thats a last resort option if Orbi needs some additional wifi signal coverage.
ARe you planning on running both R8000 and a Orbi system under 1 roof? You can. Just would be separate SSID names and channels between the two systems needs to be far appart.
- LuckyClover13Nov 24, 2021AspirantYes, the idea was to run both the X6 R8000 (bottom floor for gaming) and Orbi (top floor) RS50 under the same 2,500 square ft roof, but this does not seem practical. I would need an Orbi specific router. Maybe I just need to upgrade my Nighthawk to ensure I have more coverage for both floors…
- LuckyClover13Nov 25, 2021AspirantUpdate. I settled on the fact that I should either update my nighthawk from my current X6 R8000 to a AX6000 for broader coverage (including upstairs signal strength) up to 3500 sq.ft vs switching to an Orbi RBK752 w/ 1 satellite for you to 5000 sq.ft. Our internet speed tops out at 400 mbps, so deciding on the Orbi makes sense since we will never hit high enough speeds. Hope I’m making the best choice! Appreciate the input from the community <3
