HMTerrace
Feb 06, 2025Aspirant
Nighthawk X6 R8000 - how to reset security questions {can login]
after a firmware update, i was prompted to answer the security questions, which i failed ;
i am able to login and access all setup screens (via web browser on Windows) ;
How can I reset the security questions / answers?
Nighthawk X6 R8000
Firmware version: V1.0.5.88 _ 10.1.88
Thanks
1 Reply
You have to factory reset the router and then walk thru the setup wizard and during the process, you can input new security inputs. Be sure to write these down and keep in safe place for later use if needed.
