scennimo
Oct 06, 2022Aspirant
Nighthawk X6 R8000 - Missing remote management option
Why does my router no longer have the remote management option? I could have swear that I did have it when I first set it up. How can I get this back? Do I need to roll back the firmware? Is Netgear ...
michaelkenward
Oct 07, 2022Guru - Experienced User
scennimo wrote:
Why does my router no longer have the remote management option? I could have swear that I did have it when I first set it up. How can I get this back? Do I need to roll back the firmware? Is Netgear going to fix this?
They moved it.
It is just the manual that needs fixing:
- scennimoOct 07, 2022Aspirant
They might have moved it but the option to turn on Remote Management is not available.
- michaelkenwardOct 08, 2022Guru - Experienced User
What does "Not available" mean?
Can you see this?
Have you enabled "Always Use HTTPS to Access Router"?
If so, try turning it off.
- FURRYe38Oct 08, 2022Guru - Experienced User
NG has removed web browser based Remote Management from newer versions of FW. Seems to have started around 2020
Is only available now.
Anywhere access works just fine through the Netgear Nighthawk app.
Perhaps scennimo could explain what they want to achieve. The app, or the old style way in? Any what do they want to do when they get in there?
