scennimo
Oct 06, 2022Aspirant
Nighthawk X6 R8000 - Missing remote management option
Why does my router no longer have the remote management option? I could have swear that I did have it when I first set it up. How can I get this back? Do I need to roll back the firmware? Is Netgear ...
scennimo
Oct 07, 2022Aspirant
They might have moved it but the option to turn on Remote Management is not available.
michaelkenward
Oct 08, 2022Guru - Experienced User
What does "Not available" mean?
Can you see this?
Have you enabled "Always Use HTTPS to Access Router"?
If so, try turning it off.
