H-J
Jan 25, 2025Aspirant
Nighthawk X6 R8000 - weekly reset needed (every 7 days) due to lost connection with internet
Product: Nighthawk X6 R8000, tri band wifi router Firmware version: v1.0.5.88 (latest update per Jan. 25th 2025) The router is located downstream: Gateway: DKT Comega 79733 (fibre incoming) Teli...
H-J
Jan 30, 2025Aspirant
Hi again,
As mentioned above: "Ethernet cable between F1 router and R8000 router."
Please note, again, that everything worked well until the change of password. It has worked well for years.
And it actually works perfect in this moment.
So there is nothing wrong with the hardware setup itself. All signals goes perfectly correct.
Except once a week.
The question is; what in the software is it that, once a week, disturbs everything and forces me to reset the R8000 router?
If you still believe there is something wrong with hardware setup. Please explain why you expect the hardware setup to suddenly become a problem because of a changed password.
Thank you
michaelkenward
Jan 30, 2025Guru - Experienced User
You make two assumptions there. First that there is something in the "software", whatever that means, and that the only way to recover is to reset the router.
The router doesn't have software, If it is on the router's firmware then you may find some clues in the R8000's logs.
Given the nature of your network, it isn't easy to guess might be happening.
Reading stuff that wafts by here, those "timed" glitches can be down to something going on at the ISP. That again might show in the logs.
Then there is the possibility of some quirk in the Internet settings, or even in the password.
Again it remains unclear to me if you have answered the question from Kitsap about the "modem/router" and what it is doing in there.
As to the sudden appearance of this issue, did it happen before you updated the firmware last month? (That version actually came it in October 2024.)
By the way. the R8000 dates back to April 2015, so it is getting a bit long in the tooth.
Just another user with time on their hands.
