Retired_Member's avatar
Retired_Member
Apr 05, 2020
Nighthawk x6 R8000 2.4 GHz Dropping Wifi
Oh god, someone help me, I'm going insane.    I had a R7000 that worked fine, but I purchased a R8000 x6 - two days ago. My problem is my Wifi keeps dropping, so far its the 2.4GHz but i haven't be...
  • Retired_Member's avatar
    Retired_Member
    Apr 07, 2020
    After tril and error for about two days of constant work, I downgraded to a older firmware thats pretty old, and now everything works perfectly and as its suppose to!
    The answer was to downgrade to: Firmware Version V1.0.4.18_10.1.49
