samcasce
Oct 19, 2022Follower
Nighthawk X6 R8000 2.4 GHz Wifi with Firmware Version V1.0.4.84_10.1.84 not connect
I have router Nighthawk X6 R8000 with Firmware Version V1.0.4.84_10.1.84 where the SIID 2.4 GHz Wifi is visible on my devices but not connect and repeatdly ask for password. The password is the same...
Oct 19, 2022Guru - Experienced User
Did something change on it other than this? (like a firmware update)
Have you tried a reboot?
Or factory reset?
