Chefdaddy
Feb 04, 2023Aspirant
Nighthawk X6 R8000 2.4ghz won't broadcast
 Firmware: V1.0.4.84_10.1.84  OS: Linux Mint     While I was out of town, my printer disconnected from the wifi. The printer is fine, it picks up other SSIDs, but my router is no longer broadcasting t...
- Feb 05, 2023
I gave up and bought a new router. Thanks for helping though, much appreciated
Chefdaddy
Thanks for writing. I did those steps and I think the 2.4ghz is now sort of visible, but the signal is so weak, the printer cannot pick it up. The router and printer are practically beside one another.
Feb 04, 2023Guru - Experienced User
How long have you had the router for?
How are you determining the single is weak?
- ChefdaddyFeb 04, 2023Aspirant
I've had the router for about 1.5 years. It was a renewed one from Amazon.
The signal shows up sometimes on my phone's wifi list with 1 bar. Sometimes I can connect to it, sometimes it disappears before it has time to connect.- FURRYe38Feb 04, 2023Guru - Experienced User
What brand and model is the phone?
Does this happen with other wifi devices on the 2.4Ghz radio?
Do you have Smart Connect disable?
Using channel 1, 6 or 11 on 2.4Ghz same thing happens?
Do you have Enable WMM and beamforming and MIMO enabled and 40Mhz only selected Under Advanced Tab/Advanced Settings/Wireless Settings
- Happens across multiple models (Samsungs, Honor)Does this happen with other wifi devices on the 2.4Ghz radio?
- Don't have any other devices on the 2.4. Only laptops connected to the 5ghz.Do you have Smart Connect disable?
- Yes
- YesDo you have Enable WMM and beamforming and MIMO enabled and 40Mhz only selected Under Advanced Tab/Advanced Settings/Wireless Settings
- Yes WMM (YES QoS)- Yes Beamforming
- No MIMO - don't think my printer or my phones are compatible and can't find the setting on my router admin portal
- I unselected 20/40 mhz coexistence
