Chefdaddy
Feb 04, 2023Aspirant
Nighthawk X6 R8000 2.4ghz won't broadcast
Firmware: V1.0.4.84_10.1.84 OS: Linux Mint While I was out of town, my printer disconnected from the wifi. The printer is fine, it picks up other SSIDs, but my router is no longer broadcasting t...
- Feb 05, 2023
I gave up and bought a new router. Thanks for helping though, much appreciated
Chefdaddy
What brand and model is the phone?
- Happens across multiple models (Samsungs, Honor)
Does this happen with other wifi devices on the 2.4Ghz radio?
- Don't have any other devices on the 2.4. Only laptops connected to the 5ghz.
Do you have Smart Connect disable?
- Yes
Using channel 1, 6 or 11 on 2.4Ghz same thing happens?
- Yes
Do you have Enable WMM and beamforming and MIMO enabled and 40Mhz only selected Under Advanced Tab/Advanced Settings/Wireless Settings
- Yes WMM (YES QoS)
- Yes Beamforming
- No MIMO - don't think my printer or my phones are compatible and can't find the setting on my router admin portal
- I unselected 20/40 mhz coexistence
Feb 04, 2023Guru - Experienced User
Possible the radio maybe going bad...
- ChefdaddyFeb 05, 2023Aspirant
- FURRYe38Feb 05, 2023Guru - Experienced User
Cooling: Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
Enjoy.
