Chefdaddy
Feb 04, 2023Aspirant
Nighthawk X6 R8000 2.4ghz won't broadcast
 Firmware: V1.0.4.84_10.1.84  OS: Linux Mint     While I was out of town, my printer disconnected from the wifi. The printer is fine, it picks up other SSIDs, but my router is no longer broadcasting t...
- Feb 05, 2023
I gave up and bought a new router. Thanks for helping though, much appreciated
Feb 04, 2023Guru - Experienced User
Possible the radio maybe going bad...
Chefdaddy
Feb 05, 2023Aspirant
- FURRYe38Feb 05, 2023Guru - Experienced User
Cooling: Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
Enjoy.
