MGILL
Feb 21, 2021Aspirant
Nighthawk X6 R8000 all LEDs flashing No connection
A few months ago, we had a power outage and when the power came back, the network was down, and I found the X6 with all it's LEDs flashing like a Christmas tree (all lights in a regular pattern). It ...
Feb 22, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- MGILLFeb 22, 2021AspirantHey plemans
Many thanks for your response.
I tried tftp flash of latest firmware but as router appears to be in a perpetual state of reboot loop, I can’t maintain a connection long enough for the firmware to upload.
I can see the Ethernet connection come up for a fraction of a second before the unit reboots again. There seems to be no way of stopping this.
I haven’t tried the nmrpflash as that also seems to rely on a stable connection between PC and Router.
I fear I have a brick on my hands...?
Any other suggestions gratefully received.
Mike- plemansFeb 22, 2021Guru - Experienced User
You could try checking the power supply. Maybe its in the process of going bad.
If you have a spare supply that has the same voltage and at least the same amperage, you could try it. (check polarity as well).
And you could try nmrpflash. Maybe it'll get connection long enough to send the file.
- MGILLFeb 23, 2021Aspirant
Excellent thought re power supply. I will give that a go.
Just tried the nmrpflash and couldn't get it to go... maybe my timing... but the box only seems to have an IP address for a few millieconds and I can't get through that gap (if you see what I mean).
Thanks Mr
