sunspotmom
Dec 10, 2021Aspirant
NightHawk X6 R8000 and 2.4 anomaly
Cross posted. They suggested I try this group. Thanks for any help. I'll try suggestions tomorrow morning. Firmware Version V1.0.4.68_10.1.75 other than NightHawwk X6 R8000 I don't know a mo...
- Dec 11, 2021
In the end
Implicit beam forming is disabled
2.4 is on channel 6
I returned my pw to original - so I didn't have to possibly fix other things (Like my printer which I got going again) and I will check it and pray it stays connected.
Let me know if any of this helps you.
The end.
sunspotmom
Dec 11, 2021Aspirant
So, this morning after contemplating and procrastinating and poking around --- I noticed a checkbox that was checked (at the bottom of the advanced wireless settings page) enable implicit BEAMFORMING. I unchecked rebooted. Tried unplug/replug therm. and it worked!!!
Now I need to decide do I keep the other changes I made? re: pw without special characters and changed channel from auto to 6.
I also realize that I need to wait and make sure that it STAYS connected, but the actual process went smooth like butter. I will keep my fingers crossed.
Thanks.
- sunspotmomDec 11, 2021Aspirant
I would also like to add that my viewpoint on having to disable this "feature" is disheartening. Does'nt disabling defeat the purpose of this dual band router? My 2 cents.
BTW I am hoping this works and also helps someone else. I've seen a lot of posts related.
In the end
2.4 is on channel 6
The end.
- FURRYe38Dec 11, 2021Guru - Experienced User
Sounds like a compatiblity problem with this one device and the router. Possible age of the device. Something to consider a updated or newer generation version of this devcie if thats something available.
- sunspotmomDec 12, 2021Aspirant
Idk, I had to rework my wiifii printer suddenly also.
