sunspotmom
Dec 10, 2021Aspirant
NightHawk X6 R8000 and 2.4 anomaly
Cross posted. They suggested I try this group. Thanks for any help. I'll try suggestions tomorrow morning. Firmware Version V1.0.4.68_10.1.75 other than NightHawwk X6 R8000 I don't know a mo...
- Dec 11, 2021
In the end
Implicit beam forming is disabled
2.4 is on channel 6
I returned my pw to original - so I didn't have to possibly fix other things (Like my printer which I got going again) and I will check it and pray it stays connected.
Let me know if any of this helps you.
The end.
sunspotmom
Dec 11, 2021Aspirant
In the end
2.4 is on channel 6
The end.
Dec 11, 2021Guru - Experienced User
Sounds like a compatiblity problem with this one device and the router. Possible age of the device. Something to consider a updated or newer generation version of this devcie if thats something available.
