fredtheswimmer
May 13, 2020Tutor
Nighthawk X6 R8000 cannot login
Hi, I have just bought a Nighthawk X6 R8000 router that I'm trying to set up. I can reach routerlogin.net (using either safari or Chrome on my Macbook) but seems admin//password is not accept...
- May 14, 2020Not if its back to defaults.
Did you try a different pc/device?
or try a 30/30/30 reset?
push and hold reset for 30 seconds while powered on, then shut if off for 30 seconds while holding reset, then power it back up while still holding reset for 30 seconds.
May 13, 2020Guru - Experienced User
1. its case sensitive.
2. some don't hold reset long enough. push and hold while powered on for 7-15 seconds. The lights should blink/flash when held long enough
3. If you have any password managers, disable them. They're very good at overwriting data
4. default login: admin default password: password
- fredtheswimmerMay 14, 2020TutorThanks for the help,
Tried all of the above. Including holding reset button for 30 sec (after which the unit restarts so I guess factory reset works).
I have an older Netgear router which I can access without a problem.
Is there any circumstance under which the admin user/password is changed?- plemansMay 14, 2020Guru - Experienced UserNot if its back to defaults.
push and hold reset for 30 seconds while powered on, then shut if off for 30 seconds while holding reset, then power it back up while still holding reset for 30 seconds.- fredtheswimmerMay 14, 2020Tutor
30-30-30 reset did the trick!
And my internet speed just got bumped up by 4x =)
Thanks a lot for the support!
- labattMay 14, 2020Mentor
If this is a new router it could be a refurbish which could have an old configuration on it, BUT a reset should get rid of that. As plemans says you do need to hold the reset in for a period of time. I always waited until the lights start to flash.
Personally, if I had this issue right out of the box it would get returned as who knows what else you may run into even if you get logged in.
