fredtheswimmer
May 13, 2020Tutor
Nighthawk X6 R8000 cannot login
Hi, I have just bought a Nighthawk X6 R8000 router that I'm trying to set up. I can reach routerlogin.net (using either safari or Chrome on my Macbook) but seems admin//password is not accept...
- May 14, 2020Not if its back to defaults.
Did you try a different pc/device?
or try a 30/30/30 reset?
push and hold reset for 30 seconds while powered on, then shut if off for 30 seconds while holding reset, then power it back up while still holding reset for 30 seconds.
fredtheswimmer
May 14, 2020Tutor
Thanks for the help,
Tried all of the above. Including holding reset button for 30 sec (after which the unit restarts so I guess factory reset works).
I have an older Netgear router which I can access without a problem.
Is there any circumstance under which the admin user/password is changed?
May 14, 2020Guru - Experienced User
- fredtheswimmerMay 14, 2020Tutor
30-30-30 reset did the trick!
And my internet speed just got bumped up by 4x =)
Thanks a lot for the support!
- plemansMay 14, 2020Guru - Experienced UserGlad to hear it worked and in improved your speeds!
