Dmary123
Apr 15, 2022Aspirant
Nighthawk X6 R8000 Connecting to websites
Need to refresh most websites 2-3 times before making connection. Very frustrating. Using Firmware version V1.0.4.84. Any suggestions to fix this problem?
Apr 16, 2022Guru - Experienced User
You can also try enabling IPv6 and rebooting the router/device as well. Thats fixed it for some
Dmary123
Apr 16, 2022Aspirant
Can you give me instructions on how to do that?
- plemansApr 16, 2022Guru - Experienced User
- Dmary123Apr 16, 2022Aspirant
Thank you so much v.62 works!!!!
- FURRYe38Apr 16, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
