Dmary123
Apr 15, 2022Aspirant
Nighthawk X6 R8000 Connecting to websites
Need to refresh most websites 2-3 times before making connection. Very frustrating. Using Firmware version V1.0.4.84. Any suggestions to fix this problem?
Dmary123
Apr 16, 2022Aspirant
Can you give me instructions on how to do that?
Apr 16, 2022Guru - Experienced User
- Dmary123Apr 16, 2022Aspirant
Thank you so much v.62 works!!!!
- FURRYe38Apr 16, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
