Dmary123
Apr 15, 2022Aspirant
Nighthawk X6 R8000 Connecting to websites
Need to refresh most websites 2-3 times before making connection. Very frustrating. Using Firmware version V1.0.4.84. Any suggestions to fix this problem?
Dmary123
Apr 16, 2022Aspirant
Thank you so much v.62 works!!!!
Apr 16, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
